Broadlink RM4 pro -- controlling a projector
I bought a Broadlink RM4 pro so I could use HA to control my home theater system. The box’s IR signal gets to all of my components…except the projector which is in a different location. Since there are no jacks to use IR extenders, is there another similar product that does? Alternatively, is there another way to control the projector with HA?
Thanks!
You need an IR hub in every room that does not have one since they are line of sight for control in the rooms if there is no integration for the device in question at the time and its not using networking to connect for control via an optional app.
iirc the broadlink is wifi capable so you should be able to place it better in the room if the projector is in the same room and you just need better line of sight to try control it.
