Broadlink RM4 Pro with Livolo Switches
Hey ,
Need some help setting up something, can’t make it work at all.
My setup is:
Home assistant ( on a Hyper-V , will move it to a rasberry soon )
Broadlink RM4 Pro
Livolo RF switches for the lights ( not the zigbee version )
I can control them perfectly from the Broadlink app on my android, but when i try to learn command on Home Assistant, i get stuck at the keep button pressed because the switch just send a short burst of RF when setting up, and i can’t make it work.
I bought the RF remote from livolo for their switches, but same issue. I managed to get past the first step by clicking the remote N number of times, but then when i try to run the script to turn on/off lights, it works once in let’s say 10 attempts.
I was thinking of extracting the codes from broadlink directly, but can’t seem to make broadlink manager work, and can’t find any other way.
i would really appreciate some help.
I am facing same issue learning Livolo switch RF code, able to learn the code, but unable to use the code after learning. Have you found a solution?
Btw, I also tried to use Broadlink Manager to learn the RF code, also unable to capture the Livolo code. It seems livolo has some kind of rolling code to prevent simply relay.
