Hi all!
I’ve been using a custom ESP32 with Tasmota IR to control a STB device provided by Vodafone, I have now purchased a Broadlink RM4 Mini to replace all remotes in the room (AC, Stereo, TV & Vodafone TV) All devices except the Vodafone TV are working almost out of the box. Is there a way to translate the tasmota codes to broadlink so as to transfer to the broadlink?
I have tried to capture the codes again using the Broadlink learn but because the VTV STB transmits in a weird way each button press returns another code which makes it impossible to correctly capture. I had the same issue with Tasmota but using a Vishay IR receiver I managed to get the presses with MUCH effort.
Please if possible point me to a way to convert the codes to Broadlink language!
Below are the Tasmota codes, in case another has that STB:
Power {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000260C","DataLSB":"0x0C006430","Repeat":0,"RawData":[460,266,178,264,178,766,174,264,202,238,182,264,178,266,178,268,174,262,178,268,178,596,178,430,178,600,178,268,178,258,178,766,178,262,178],"RawDataInfo":[35,35,0]}}
1 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002601","DataLSB":"0x0C006480","Repeat":0,"RawData":[484,242,184,234,232,710,232,238,204,234,208,238,202,240,206,240,202,234,208,238,204,548,232,376,208,568,232,238,182,236,232,234,206,382,204],"RawDataInfo":[35,35,0]}}
2 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002602","DataLSB":"0x0C006440","Repeat":0,"RawData":[484,244,202,240,184,732,232,240,178,236,208,234,232,238,180,240,208,218,220,236,208,568,208,402,232,544,208,262,208,238,204,236,204,544,208],"RawDataInfo":[35,35,0]}}
3 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002603","DataLSB":"0x0C0064C0","Repeat":0,"RawData":[460,240,208,238,204,736,204,268,180,234,204,240,204,268,178,240,204,236,204,268,180,568,208,402,208,568,208,238,204,240,204,264,178,736,208],"RawDataInfo":[35,35,0]}}
4 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002604","DataLSB":"0x0C006420","Repeat":0,"RawData":[456,272,174,264,180,768,174,264,178,264,180,268,174,268,178,264,180,264,178,264,178,602,174,430,178,598,178,268,180,260,178,434,178,260,178],"RawDataInfo":[35,35,0]}}
5 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002605","DataLSB":"0x0C0064A0","Repeat":0,"RawData":[460,268,180,238,204,736,208,240,202,236,202,240,208,240,204,238,204,236,208,264,178,568,208,402,208,568,208,268,176,238,208,398,208,402,208],"RawDataInfo":[35,35,0]}}
6 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002606","DataLSB":"0x0C006460","Repeat":0,"RawData":[484,242,204,236,204,716,232,236,204,240,204,238,184,234,232,238,182,258,182,236,232,574,204,378,208,568,236,236,204,234,180,410,228,544,228],"RawDataInfo":[35,35,0]}}
7 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002607","DataLSB":"0x0C0064E0","Repeat":0,"RawData":[484,242,204,240,204,712,232,240,204,234,180,238,232,240,204,238,180,260,184,234,232,544,232,378,208,568,208,236,232,240,204,376,232,708,208],"RawDataInfo":[35,35,0]}}
8 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002608","DataLSB":"0x0C006410","Repeat":0,"RawData":[484,236,182,236,232,708,208,238,232,234,204,240,178,240,232,240,202,236,204,238,208,544,208,402,232,544,232,238,204,238,208,540,232,240,204],"RawDataInfo":[35,35,0]}}
9 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002609","DataLSB":"0x0C006490","Repeat":0,"RawData":[484,244,204,240,202,710,232,240,178,236,232,238,204,240,182,236,232,234,204,240,182,568,232,378,208,568,208,236,232,240,208,540,232,382,208],"RawDataInfo":[35,35,0]}}
0 {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002600","DataLSB":"0x0C006400","Repeat":0,"RawData":[484,240,182,236,232,706,236,242,200,234,184,234,210,234,232,240,208,234,204,238,204,544,212,398,208,568,212,234,232,238,180,234,208,234,232],"RawDataInfo":[35,35,0]}}
|<- {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000264D","DataLSB":"0x0C0064B2","Repeat":0,"RawData":[484,244,204,238,204,712,232,238,204,236,178,240,232,240,204,240,182,256,184,234,232,572,204,378,232,544,232,378,208,236,232,712,204,402,232],"RawDataInfo":[35,35,0]}}
->| {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000264C","DataLSB":"0x0C006432","Repeat":0,"RawData":[460,268,178,264,180,764,178,264,180,262,180,264,178,268,178,264,180,258,180,268,178,596,180,430,178,596,180,430,180,264,178,764,178,264,178],"RawDataInfo":[35,35,0]}}
<< {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000262B","DataLSB":"0x0C0064D4","Repeat":0,"RawData":[466,264,182,218,220,762,180,258,210,238,204,238,184,262,206,238,204,234,184,262,206,570,206,404,204,570,206,238,184,596,204,568,204,738,186],"RawDataInfo":[35,35,0]}}
>|| {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002633","DataLSB":"0x0C0064CC","Repeat":0,"RawData":[460,268,178,268,204,738,176,264,202,240,204,238,184,264,202,240,178,264,178,264,204,576,174,430,178,602,178,264,204,740,178,264,178,764,180],"RawDataInfo":[35,35,0]}}
>> {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000262A","DataLSB":"0x0C006454","Repeat":0,"RawData":[486,240,180,232,210,736,234,232,206,236,186,232,234,236,210,236,206,232,180,236,234,544,206,428,206,570,186,232,234,546,206,566,234,568,206],"RawDataInfo":[35,35,0]}}
Back {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002683","DataLSB":"0x0C0064C1","Repeat":0,"RawData":[486,240,206,236,210,704,214,232,234,232,182,236,234,236,182,236,234,232,206,236,186,566,234,374,234,540,234,540,214,232,234,232,206,712,234],"RawDataInfo":[35,35,0]}}
Menu {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002654","DataLSB":"0x0C00642A","Repeat":0,"RawData":[460,266,180,258,184,766,180,260,202,240,178,268,202,240,178,268,204,234,204,238,182,598,202,406,202,572,204,406,204,406,178,434,178,260,204],"RawDataInfo":[35,35,0]}}
Exit {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002655","DataLSB":"0x0C0064AA","Repeat":0,"RawData":[460,266,204,238,178,764,204,234,182,266,200,238,182,264,204,238,182,260,204,238,178,600,180,430,178,596,204,406,202,406,180,430,204,410,202],"RawDataInfo":[35,35,0]}}
Mic {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x300026D2","DataLSB":"0x0C00644B","Repeat":0,"RawData":[464,262,184,262,204,738,204,238,182,256,208,238,202,240,206,240,178,258,208,238,204,576,178,426,184,596,204,738,204,406,178,264,202,572,182],"RawDataInfo":[35,35,0]}}
UP {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002658","DataLSB":"0x0C00641A","Repeat":0,"RawData":[484,244,204,238,204,714,228,238,208,234,204,240,202,240,206,240,178,234,232,238,204,548,208,402,204,572,232,376,208,402,204,572,206,236,232],"RawDataInfo":[35,35,0]}}
RIGHT {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000265B","DataLSB":"0x0C0064DA","Repeat":0,"RawData":[484,242,184,234,232,710,232,238,204,238,180,234,232,238,208,240,202,236,182,264,202,544,232,376,232,544,212,398,208,402,232,544,236,706,232],"RawDataInfo":[35,35,0]}}
LEFT {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000265A","DataLSB":"0x0C00645A","Repeat":0,"RawData":[484,242,204,240,204,710,208,234,208,234,208,234,232,238,182,236,232,234,204,240,206,548,228,378,232,544,232,380,228,378,232,548,228,548,204],"RawDataInfo":[35,35,0]}}
DOWN {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002659","DataLSB":"0x0C00649A","Repeat":0,"RawData":[484,240,202,240,204,706,212,234,232,236,182,236,232,238,180,238,232,234,204,238,184,564,236,374,212,564,236,374,210,398,232,544,212,398,208],"RawDataInfo":[35,35,0]}}
OK {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000265C","DataLSB":"0x0C00643A","Repeat":0,"RawData":[486,240,204,238,208,706,232,238,208,236,202,240,204,238,208,240,204,234,178,240,208,572,228,378,208,572,228,378,232,378,208,734,232,234,184],"RawDataInfo":[35,35,0]}}
V+ {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002610","DataLSB":"0x0C006408","Repeat":0,"RawData":[484,240,182,236,232,712,208,234,232,234,204,240,182,236,232,240,202,236,182,236,232,548,228,378,232,572,204,240,202,406,204,238,180,264,208],"RawDataInfo":[35,35,0]}}
V- {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002611","DataLSB":"0x0C006488","Repeat":0,"RawData":[484,240,206,240,178,736,232,240,178,260,182,236,232,238,184,234,232,236,204,238,208,544,232,376,232,544,232,238,184,402,228,240,206,378,208],"RawDataInfo":[35,35,0]}}
REC {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002637","DataLSB":"0x0C0064EC","Repeat":0,"RawData":[484,242,204,238,182,732,208,238,208,218,220,240,206,234,232,238,182,220,220,234,232,544,212,398,232,544,212,238,230,706,236,372,212,732,208],"RawDataInfo":[35,35,0]}}
MUTE {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000260D","DataLSB":"0x0C0064B0","Repeat":0,"RawData":[456,242,204,238,208,734,204,238,208,234,204,238,208,238,204,238,204,234,208,238,204,572,208,400,204,572,208,238,204,238,208,734,204,404,204],"RawDataInfo":[35,35,0]}}
CH+ {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002620","DataLSB":"0x0C006404","Repeat":0,"RawData":[484,242,180,238,232,706,208,240,232,234,180,238,232,238,178,264,184,218,220,234,208,568,212,398,208,568,212,236,232,544,208,236,232,238,204],"RawDataInfo":[35,35,0]}}
CH- {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002621","DataLSB":"0x0C006484","Repeat":0,"RawData":[484,240,182,234,232,712,230,240,204,234,184,236,206,264,178,268,204,234,204,238,184,568,232,378,232,544,232,238,204,548,232,236,204,380,232],"RawDataInfo":[35,35,0]}}
RED {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000266D","DataLSB":"0x0C0064B6","Repeat":0,"RawData":[460,268,204,240,182,760,178,268,180,258,180,264,204,238,184,264,204,234,180,268,178,598,178,430,178,598,178,430,174,602,178,760,178,430,178],"RawDataInfo":[35,35,0]}}
GREEN {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000266E","DataLSB":"0x0C006476","Repeat":0,"RawData":[460,268,178,264,178,764,180,266,176,264,174,268,178,268,174,268,180,258,180,268,178,598,178,430,178,596,180,430,180,596,180,762,176,600,178],"RawDataInfo":[35,35,0]}}
YELLOW {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x3000266F","DataLSB":"0x0C0064F6","Repeat":0,"RawData":[484,242,204,234,184,734,232,240,178,234,232,238,182,236,232,240,178,234,232,238,204,548,204,402,232,548,204,402,232,548,208,730,232,710,232],"RawDataInfo":[35,35,0]}}
BLUE {"IrReceived":{"Protocol":"RCMM","Bits":32,"Data":"0x30002670","DataLSB":"0x0C00640E","Repeat":0,"RawData":[484,240,202,240,182,736,228,240,182,222,216,234,232,238,208,238,204,234,184,234,232,548,228,382,228,548,228,382,228,710,232,238,204,238,184],"RawDataInfo":[35,35,0]}}
