Broken YAML line 3 column 1
??? I just tried to add something to my config.yaml (nowhere near line 3) and i’ve broken it on line three, even though I didn’t touch line three???
end of the stream or a document separator is expected at line 3, column 1:
    default_config:
Error loading /config/configuration.yaml: expected '<document start>', but found '<block mapping start>'
in "/config/configuration.yaml", line 3, column 1
So confused, even after taking out the added code, still getting the same error… WTF LOL?
Here re the first few lines:
homeassistant
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
withings:
The issue appears to be on line 1, it should be homeassistant: (you’re missing the colon)
Its always something simple isn’t it HAHA
Thanks mate :slight_smile:
Hey!
I get the same error
end of the stream or a document separator is expected (9:1)
  6 |
  7 | ########################## Müll ...
  8 |
  9 | waste_collection_schedule:
 10 | - platform: waste_collection_sc ...```
```########################## Müllabfuhr ###########################
- platform: waste_collection_schedule
  value_template: '{{value.date.strftime("%d.%m.%Y")}}'
  types:
    - Papiertonne
  value_template: "{{value.daysTo}}"
  types:```
Thanks!
Br
