Anyone able to use the variable area:
I get this error when i “check configuration”:
Invalid config for [sensor.brottsplatskartan]: value is not allowed @ data['area'][0]. Got 'D'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.brottsplatskartan/
The name:
variable works fine.
My yaml configuration:
- platform: brottsplatskartan
name: "Brott i Dalarna"
area: "Dalarnas Län"
If i restart anyway i get this error in the log:
2019-01-10 11:53:19 ERROR (MainThread) [homeassistant.components.hassio] INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /config
Failed config
sensor.brottsplatskartan:
- Invalid config for [sensor.brottsplatskartan]: value is not allowed @ data['area'][0]. Got 'D'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.brottsplatskartan/
area: Dalarnas Län
name: Brott i Dalarna
Successful config (partial)
Ping @chrillux
