Bryant / Carrier SAM module?
I’m in process of building a new house and guest house with Bryant equipment.
The house has a 4-ton variable speed / zoned heat pump and another 2-ton variable speed /zoned heat pump.
The guest house has a 2-ton variable speed heat pump (one zone).
Is there any value in adding a SAM for each of these systems? The HVAC guy lists the part number as “ SYSTXBBNIMO1”
Thanks for your help.
