Btcino (Myhomeserwer1)
Hi everyone,
I would really appreciate your help with configuring the BTicino My Home Server platform in Home Assistant.
I already have Home Assistant running and would like to connect it with my BTicino My Home Server 1. Unfortunately, I’m running into issues during the setup – I’m not sure which configuration files need to be modified and what exact data (IP, ports, credentials) should be provided to make the integration work properly.
If anyone here has experience integrating BTicino / Legrand with HA and could share a step-by-step guide or an example YAML configuration, I’d be very grateful.
Thanks a lot in advance for any guidance!
If are you using Raspberry there is another way to integrate
