Bticino Living Now: Delayed Light/Shutter Status Updates
I have set up my entire home with Home Assistant and have just started testing it.
Among other things, I also have shutters and lights with Bticino Living Now, and I have configured these switches using the Netatmo integration. However, I notice significant delays in updating the status on HA. For example, if I turn on the light from the switch, the ON state appears on HA only after a few minutes.
Did I do something wrong? Is this a common issue, and are there any solutions?
Thanks.
Hello Donato Di Stasi,
Chances are that these are Tuya based devices and control their function by asking a China server in the cloud what to do first.
Thanks,
maybe buying a Zigbee dongle like this and configuring everything with this Zigbee instead of its gateway can solve the problem?
Yes a SONOFF Zigbee Dongle-P is a great choice. I would also suggest SLZB-06s if they are available to you. I run a mix of both, but feel the SLZBs perform better.
Thanks!
Yes, the SLZB-06s is available. There is a €100 difference between the two devices, so I might start with the SONOFF Zigbee Dongle-P if it’s a good choice.
Maybe in the future, I can upgrade my Home Assistant by purchasing the SLZB-06s.
