⚪ Bubble Card - A minimalist card collection for Home Assistant with a nice pop-up touch
My system is up-to-date and running on a Mini PC with an Intel N100.
I’ve done some testing, and it seems the issue lies with using custom:hui-element. When I add the bubble-card for the popup, it stops working.
To put it simply I am not icon does not change, even though I think it should.
${subButtonIcon[0].setAttribute("icon", hass.states['media_player.optiplex_snapcast_client'].attributes.is_volume_muted ? 'mdi:volume-off' : 'mdi:volume-high')}
here is the code for the card:
type: custom:bubble-card
card_type: button
entity: media_player.optiplex_snapcast_client
button_type: slider
force_icon: false
show_state: true
slider_live_update: true
show_attribute: false
card_layout: large
tap_action:
  service: ""
styles: >-
  .bubble-range-fill {
    background: rgba(79, 69, 87, 1) !important;
    opacity: 1 !important;
sub_button:
  - entity: media_player.optiplex_snapcast_client
    show_last_changed: false
    show_state: false
    show_name: false
    show_icon: true
    state_background: false
    show_background: true
    tap_action:
      action: call-service
      service: script.toggle_media_player_mute
        entity_id: media_player.optiplex_snapcast_client
      target: {}
Thanks in advance
First I want to thank you. Really love the media player!
But I got a little issue. If I press the volume button and close it again the music info disappears and the volume button stays an X. Did I do anything wrong?
ezgif-3-730f0810ad
card_type: media-player
entity: media_player.ray_wohnzimmer
show_last_changed: true
cover_background: true
styles: |-
  .bubble-media-player-container {
      background: transparent;
  .bubble-play-pause-button {
    background-color: transparent;
show_icon: true
hide:
  power_button: true
Thanks in advance for any help.
Already fixed that.
Will come in the next release, PR was already merged:
My vertical stack does not look like that:
type: vertical-stack
cards:
  - type: custom:bubble-card
    card_type: pop-up
    hash: "#POP-GF-HW-LAMP"
    button_type: slider
    entity: light.dev_ff_hw_lamp
    show_attribute: true
    attribute: brightness
    sub_button:
      - entity: light.dev_ff_hw_switch
        show_state: true
        state_background: true
        show_icon: true
        tap_action:
          action: toggle
        double_tap_action:
          action: more-info
        hold_action:
          action: more-info
could you get rid of the custom:hui-element
Apparently it seems that to use the vertical-stack inside a picture-elements the only way is to use custom:hui-element
I’m having a issue regarding the bubble card. The image is shown correctly, but I can’t get the yellow background away. I want this to be not visible. It’s not in my picture itself. Tried everything with css properties, but maybe someone can help me?
I use the following code:
    icon: mdi:home-roof
    entity: binary_sensor.sensor_bijschuur_contact
    card_type: button
    button_type: state
    show_name: true
    show_state: false
    tap_action:
      action: navigate
      navigation_path: /lovelace-mushroom/zolder
    button_action:
      tap_action:
        action: navigate
    sub_button:
      - show_background: false
        entity: binary_sensor.motion_sensor_extra_beweging
        show_name: false
        show_state: false
        show_icon: true
      - entity: sensor.power_3
        show_name: false
        attribute: raw_state
        show_state: true
    card_layout: large-2-rows
    styles: |-
      .bubble-icon{
        --icon-primary-color: red;
      .bubble-entity-picture{
        background-image: url('/local/icons/bed.png') !important;
        display: block !important;
        background-size: cover !important;
vBouNsg184
Thank you!
You’re doing some exotic thing I guess.
Could you please make a github discussion in the category ‘questons about config’ and then share the whole yaml of the view.
This won’t be solved in 1 go.
Have you tried with a different picture?
I don’t have issues with this one:
[https://png.pngtree.com/png-clipart/20221227/original/pngtree-illustration-of-banyan-tree-with-hanging-roots-png-image_8811134.png]
Sure, the whole yaml is very big, but I can reproduce the problem with a simpler example, like I did here.
Same thing :frowning:
oDpQK2PfjS
Do you use a theme?
This variable is used for the background color of the .bubble-icon-container.
background-color: var(--bubble-button-icon-background-color, var(--bubble-icon-background-color, var(--bubble-secondary-background-color, var(--card-background-color, var(--ha-card-background)))));
Use this to overwrite it.
  .bubble-icon-container{
    background-color: purple;
Ah check. This pointed me in the right direction! Thanks!
Still got one problem left. Maybe someone knows this.
I can see the icon, but not completely, see below.
Is there a smart way to do this? Checked all of the below and played with it, but does not make it all visible
  .bubble-entity-picture {
    background-image: url('/local/icons/chair.png') !important;
    background-position: center center !important;
    background-repeat: no-repeat !important;
    height: 100% !important;
    width: 100% !important;
    border-radius: 0 !important;
LsYl2aUr5W
Do this hack from a week ago:
For the size of the image.
Read-up: background-size - CSS: Cascading Style Sheets | MDN
Hi everyone! Love this bubble card, but it looks like I cannot make the background of my buttons same as my other for the theme I am using (btw is ios-dark-mode-blue-red from GitHub - basnijholt/lovelace-ios-themes: ❤️📱🏠🤖 Themes inspired by iOS Dark ⬛️ and Light ◻️ Mode for Lovelace Home Assistant with different backgrounds):
Can you help please?
This is what I am seeing as html parsed code for these buttons background:
Thanks!
Did you get this to work? I’ve checked this site and changed different css parameters, but still it does not show all of the picture.
I’ve also used the trick you linked and setted the 3 css parameters with them.
Thanks! :slight_smile:
You are missing a comparison value. Assuming that this attribute exists, you have not defined which value it needs to have for the one icon and otherwise for the other.
Ah I see I tried both ways but now I realize I had
=== `true`
but needed to remove the backticks
I’ve now used your bubble room card and converted it to my dashboard. Can you give me some advice on how I can arrange the subbuttons? I want the subbuttons to always be the same distance from each other. For example, if I only have 3, only the one at the bottom should disappear and the 3 remaining ones should keep their distance.
I’ve been testing the room cards that have been designed and really like what i plan to do. but in my testing there is this small issue. when i click on the icon to make the bubble card pop up… the cards in the background shift down a few millimeters. I am not sure why. I can’t make the gif down to 3mb or less to show…
Untitled video2 - Made with Clipchamp
