Juggler
(SR)
April 10, 2025, 5:09pm
1
I’m trying to get the background of my Bubble Card to conditionally flash. Using the following template, I do get 1 flash, however it does not continue. Can anyone help me on this?
type: custom:bubble-card
card_type: button
entity: alarm_control_panel.main_alarm_partition
sub_button:
- icon: mdi:dots-horizontal
tap_action:
action: navigate
navigation_path: "#alarm"
show_background: false
button_action:
tap_action:
action: navigate
button_type: state
styles: |-
.bubble-button-background {
opacity: 1 !important;
animation: ${state === 'arming' ? 'fade-animate 3s ease-in-out infinite' : '' };
background-color: ${state === 'armed_home' ? 'red' : state === 'armed_away' ? 'red' : state === 'arming' ? 'orange' : 'default' } !important;
@keyframes fade-animate {
0%, 100% {
opacity: 1;
50% {
opacity: 0;
I am not using Bubble card.
But the animation itself is correct:
animation: fade-animate 3s ease-in-out infinite;
0%,100% {
opacity: 1;
50% {
opacity: 0;
What COULD BE wrong - is using “${” things here.
The “styles: |-” says that the whole “styles” values is a string.
Are you sure that you can use “${}” here?
Are you sure that it is properly processed by the card?
Are you sure it should not be like
styles: >-
"xxx {xxx: xxx; xxx: xxx;} xxx {xxx: xxx; xxx: xxx;}" +
some JS expressions +
"some more css styles"
(as I said - no idea about the Bubble card & if it supports JS)
VietNgoc
(Ngoc John)
April 11, 2025, 2:31am
3
Probably the state changed to 1 sec only, so the animation could not finish.
Checked here with same code.
code
<!DOCTYPE html>
<html>
<head>
<style>
div {
width: 100px;
height: 100px;
background-color: red;
position: relative;
0%,100% {
opacity: 1;
50% {
opacity: 0;
</style>
</head>
<body>
<h1>CSS Animation</h1>
<div></div>
<p><b>Note:</b> When an animation is finished, it goes back to its original style.</p>
</body>
</html>
It is blinking continuously.
You are probably right - it has no enough time to complete.
Juggler:
background-color:
Like this
card_type: button
entity: light.night_stand
styles: |-
animation: ${hass.states['light.night_stand'].state === 'on' ? 'fade 1s linear infinite' : ''};
@keyframes fade{
0%,100% {
opacity: 1;
50% {
opacity: 0;
I used a light as an example as I don’t have my alarm system integrated.
Juggler
(SR)
April 11, 2025, 3:12pm
6
I figured out my problem… it was the !important tag. Essentially the animation was being hidden by this. Once I removed this, I got the desired effect. A side benefit is that the final state is a red background with 50% opacity – I think it looks good (see below).
For completeness, here is my .yaml. Thank you to everyone for your help!
card_type: button
sub_button:
tap_action:
action: navigate
button_action:
tap_action:
action: navigate
button_type: state
styles: |-
animation: ${state === 'arming' ? 'blink 2s ease infinite' : '' };
background-color: ${state === 'armed_home' ? 'red' : state === 'armed_away' ? 'red' : state === 'arming' ? 'orange' : 'default' };
@keyframes blink {
0% {
opacity: 0;
50% {
opacity: 1;
100% {
opacity: 0;
