After updating to Home Assistant 2025.5, I noticed that the custom colors defined in my theme for alarm_control_panel states are no longer being respected in dark mode. They still work correctly in light mode.
These colors worked perfectly in both modes before the update. After moving to 2025.5, dark mode seems to ignore these values and falls back to the system default colors, while light mode still applies the custom ones correctly.
I’ve double-checked that all variable names are correct and reloaded the themes multiple times. The issue seems to affect the native alarm-panel-card.
Is anyone else experiencing this? Could it be related to the theme variable changes introduced in 2025.5?
Appreciate any input or confirmation from other users—or devs who might look into this.
My custom alarm panel colours are still being applied but I don’t use “modes”. I have separate themes for day and night that are switched by automation.
If it does turn out to be a real issue it can be reported here:
