I did an update to Home Assistant Core 2022.2.00 yesterday. Raspi 8GB 64 bit (brand new).
After that my overviews Kitchen and Home “melt” together.
Whenever I klick “Kitchen” it was “Home” to see and visa versa.
The cards on each overview was not to see anymore (blanc).
It was also not possible to delete “Kitchen” or “Home” without deleting the other once, too.
When I install the backup everthing works fine.
I won’t install Home Assistant Core 2022.2.00 again:-(
Update form 4th February:
2022.2.1 also not work:-(
Same bug.
Update form 5th February:
2022.2.2 also not work:-(
Same bug.
Same bug.
2 taps “Kitchen” & “Home-Tab” in the overview with different designs and cards before the update.
Everthing works fine. 2 clicks no the different taps, two different overwievs. Everthing normal.
After the update you can click on each of them but I see only the overviewand cards from “Home-Tab”.
When I click “Kitchen-Tab” it is underlined but you see the “Home-Tab”.
When I try to delete the “Kitchen-Tab” the next tab e.g. “living room-Tab” will show the cards and design from “Home-Tab”, too.
So I can delete tab by tab until no more tab is ther anymore… everything look like the “Home-Tab”.
When I install the backup everthing works then before.
