I’m using the input_datetime helper for my alarm and I just noticed when changing the hour digit to 2 it always goes to 3. Originally I thought maybe it was a DST issue so I restarted my server. Upon further investigation all the hour digits change correctly except the number 2. I made a new input_datetime helper to experiment and it does the same thing. I did update to 2025.3.1 this morning so maybe it’s a bug? Has anyone else experienced this?
You should share the Card type(s), the type of Input Datetime where you are seeing this issue, as well as the browser or app you are using to access HA. It might also help if you post the card configuration.
The mushroom entity card is what I’m using. I tried a new card using tile card and it did the same thing,.
Today it is working fine. Strange.
