BUG: yaml editor search error in automation
It looks there is search error in yaml editor of automations. When searching for a word that is out of view, the editor do not move to the position that is found. If you do so in yaml of raw dashboard it works fine ?
Hi, try by refreshing your browser or use another one to see if there is any difference.
Hi, yes, it’s the same in firefox and edge.
HA core version 2025.4.2
Works for me. I just tested it in firefox.
You’re not using any add-ons in your browser?
Edge without add-ons, firefox with 3.
It’s strange because the yaml editor of HA is the same for dashboards and automations, isn’t it ?
Maybe try FF without add-ons?
I’m running FF with 20 or so extensions. Nothing that modifies the behavior of FF though.
I have the same problem.
While searching in automation yaml editor the Window does not move.
In the dashboard code editor it works ok as before.
My system:
Home Assistant:
Core 2025.4.4
Supervisor 2025.04.0
Operating System 15.2
Frontend 20250411.0
Windows 11 24H2
Browsers:
Firefox 137.0.2
Chrome 135.0.7049.115
Microsoft Edge 135.0.3179.98
Also tested in Windows 10 and Linux Mint (VirtualBox VM)
I think, there could be a problem with the number of lines in the editor window.
In my window there are 35 visible lines.
I am testing with a 45-lines-automation.
Cursor-Position line 1:
Pressing and holding the arrow-down-key: Cursor moves down and disappears, no screen updating.
Ctrl+End: Cursor disappears, no screen updating
After pressing Pgdn-key 3 times the screen ist finally updated.
Cursor position last line:
Pressing arrow-up-key 11 times until the cursor appears in line 35
Pgup-key works ok.
Ctrl-Home works ok
Just tested with an older Version of my System on a VM.
Searching and moving in the yaml automation editor works fine.
Core 2025.3.4
Supervisor 2025.04.1
Operating System 15.0
Frontend 20250306.0
Further test:
Test system:
Core 2025.3.3
Frontend 20250306.0
Searching and moving in yaml-automation editor ok
Doing just the core-update, no other manipulation in the test system.
Test System:
Core 2025.4.4
Frontend 20250411.0
Searching and moving in yaml-automation editor not ok.
@tempuser
Yes, I tested it after your comment, it’s really strange, the first 3 PgDn keypresses are ignored, then you can use PgDn to go through the complete source code.
The problem was definitely not in previous versions, I would have noticed that immediately.
Just updated to the last core version:
Core 2025.5.0
Frontend 20250507.0
Problem is still there.
Deleted all automations in my test system.
Created a new automation.
Updating to
  • Core 2025.5.1
  • Supervisor 2025.04.1
  • Operating System 15.2
  • Frontend 20250509.0
BUG is still there !
Guys, someone needs to replicate the issue in order for anyone to fix it. Updating and hoping it gets fixed without creating an issue first does nothing. I doubt anyone outside this thread even knows about this issue because it doesn’t affect many people.
What to do:
  1. Find out how to replicate the issue.
  2. Create an issue in homeassistant/frontend repo with your findings.
What not to do:
  1. Update and expect it to be fixed.
  2. Come here and complain that it hasn’t been fixed when the dev’s don’t even know about it.
Not a complaint, just acknowledgement: I just tested it now myself and I get the same behavior.
The search function works, as in highlighting the keyword outside of actual view, but not navigating to it.
So @HAUser2023 as @petro suggests: if you want it fixed (or at least let the right persons know), open an issue on GH.
I do so yesterday, hope they find the problem
@HAUser2023
Thank you for opening the case in Github!
Here some Information for the case:
“BUG: automation yaml editor search error #25437
Last known good for me (not backuping every day):
Core 2025.3.4
Tested in safe mode:
@HAUser2023
Maybe you could refer in Github to this community post.
No offense guys, but this post doesn’t have any relevant that helps anyone find the issue. It’s just a full thread of people saying they have the issue. Linking likely won’t provide any new info.
