A few weeks ago, I came across the UniFi AI Key, a system that intelligently analyzes security footage and makes it searchable using AI. The idea fascinated me β imagine being able to instantly find motion events like a person near the front door, a package delivery, or an unknown vehicle pulling up just by typing a simple search query.
Instead of purchasing the UniFi AI Key, I decided to take on the challenge of building my own AI-powered motion search system from scratch using Home Assistant, AppDaemon, LLM Vision, and Google Gemini/Ollama.
This article outlines the entire process, with full code samples and integration details.
Key Components Used
Home Assistant β Smart home automation platform.
AppDaemon β Python automation for Home Assistant.
LLM Vision β AI-powered image analysis for motion detection.
Google Gemini/Ollama β AI model for analyzing motion events.
SQLite Database β Stores motion event descriptions and video links for future searches.
How It Works
Motion Detection & Recording β Cameras detect motion and automatically record short video clips.
AI Analysis (Google Gemini/Ollama via LLM Vision) β The AI analyzes what caused the motion and generates a concise, human-readable description.
Storing Data in a Custom Database (SQLite) β Motion videos and AI-generated descriptions are saved for future searchability.
AI-Powered Search β Users can find specific events by searching in natural language (e.g., βShow me all people approaching my front doorβ).
Web Interface for Searching & Filtering β A simple front-end UI allows users to browse, filter, and search motion events by date, time, and AI description.
Step 1: Setting Up Motion Detection & Recording
The first step is configuring Home Assistant to detect motion and record video.
Home Assistant Automation (Triggers AI Processing)
This automation listens for motion detection events and triggers a script to process the video.
alias: Ring Door Bell Camera - Video on motion
description: ""
triggers:
- platform: state
entity_id:
- binary_sensor.door_bell_person_detection
to: "on"
actions:
- metadata: {}
service: script.camera_ring_video_ai_notification
mode: single
Step 2: Capturing Video & AI Processing
When motion is detected, a script handles the AI analysis, saves the video, and triggers notifications.
Home Assistant Script
sequence:
- variables:
timestamp: "{{ now().strftime('%Y%m%d_%H%M%S') }}"
camera_name: front_door
- metadata: {}
service: camera.snapshot
entity_id: camera.front_door
filename: ./www/snapshots/{{ camera_name }}_motion_{{ timestamp }}.jpg
- metadata: {}
service: camera.record
filename: ./www/videos/{{ camera_name }}_motion_{{ timestamp }}.mp4
duration: 10
- delay: "00:00:12"
- metadata: {}
service: google_generative_ai_conversation.generate_content
prompt: >-
Motion detected. Analyze the video feed from my driveway camera and describe what caused the motion alarm- Focus only on **moving objects** (people, animals, or vehicles).
- **Do NOT describe stationary objects, buildings, or parked cars** (including my blue Mercedes-Benz B-Class or Mitsubishi Colt).
- If a vehicle caused motion, describe it and extract the **license plate** (if visible).
- If no clear motion is detected, return: "No Obvious Motion Detected."
- Keep the response brief and suitable for a phone notification.
image_filename:
- ./www/snapshots/{{ camera_name }}_motion_{{ timestamp }}.jpg
response_variable: generated_content
- event: ai_video_event
event_data:
video: >-
http://192.168.1.100:8123/local/videos/{{ camera_name }}_motion_{{ timestamp }}.mp4
ai_message: "{{ generated_content['text'] }}"
mode: single
Step 3: Storing AI Results in a Database
Since Home Assistant does not store AI-generated metadata, I built an AppDaemon app to save motion event details in an SQLite database.
Python AppDaemon Code (Stores Video Links & AI Messages) β motion_video_saver.py
import appdaemon.plugins.hass.hassapi as hass
import sqlite3
class SaveVideoAI(hass.Hass):
def initialize(self):
self.listen_event(self.store_ai_results, "ai_video_event")
self.ensure_db_exists()
def ensure_db_exists(self):
"""Ensure that the database and table exist."""
db_path = "/homeassistant/custom_snapshots.db"
try:
with sqlite3.connect(db_path) as conn:
cursor = conn.cursor()
cursor.execute("""
CREATE TABLE IF NOT EXISTS motion_videos (
id INTEGER PRIMARY KEY AUTOINCREMENT,
timestamp DATETIME DEFAULT CURRENT_TIMESTAMP,
video TEXT,
ai_message TEXT
conn.commit()
self.log("Database and table verified.")
except Exception as e:
self.log(f"Error creating database: {str(e)}", level="ERROR")
def store_ai_results(self, event_name, data, kwargs):
"""Store AI snapshot data in the database."""
# Retrieve the snapshot filename and AI message
video = data.get("video", "")
ai_message = data.get("ai_message", "")
try:
cursor.execute(
INSERT INTO motion_videos (video, ai_message)
VALUES (?, ?)
(video, ai_message),
conn.commit()
self.log("Saved video data successfully.")
self.log(f"Error saving video data: {str(e)}", level="ERROR")
Step 4: Creating an API for Searching Videos
To make the stored data accessible, I built an API using AppDaemon.
Python API to Fetch Data β video_api.py
import sqlite3
import requests
GEMINI_API_KEY = "YOUR API KEY"
GEMINI_URL = f"https://generativelanguage.googleapis.com/v1beta/models/gemini-pro:generateContent?key={GEMINI_API_KEY}"
class VideoAPI(hass.Hass):
self.log("Video API running...")
self.register_endpoint(self.handle_request, "videos")
self.register_endpoint(self.ai_search, "video_search")
def handle_request(self, data, args):
"""Fetch all videos from the database"""
try:
conn = sqlite3.connect(db_path)
cursor.execute("SELECT id, timestamp, video, ai_message FROM motion_videos ORDER BY timestamp DESC")
rows = cursor.fetchall()
conn.close()
videos = [{"id": row[0], "timestamp": row[1], "video": row[2], "ai_message": row[3]} for row in rows]
return {"videos": videos}, 200
except sqlite3.OperationalError as e:
self.log(f"Database error: {e}", level="ERROR")
return {"error": "Database query failed."}, 500
def ai_search(self, data, args):
"""Process natural language search using Google Gemini AI"""
query = data.get("query", "").strip()
self.log(f"Received AI search query: {query}", level="INFO")
if not query:
return self.handle_request(data, args)
cursor.execute("SELECT id, timestamp, video, ai_message FROM motion_videos ORDER BY timestamp")
conn.close()
if not rows:
return {"error": "No videos found in the database."}, 200
ai_messages = [row[3] for row in rows]
formatted_messages = "\n".join([f"- {msg}" for msg in ai_messages])
prompt_text = (
f"You are analyzing AI-generated security camera messages. Given the following motion detection descriptions:\n\n"
f"{formatted_messages}\n\n"
f"Identify which messages are most relevant to the query: '{query}'. Return only the messages that match."
payload = {
"contents": [
"parts": [
{"text": prompt_text}
headers = {"Content-Type": "application/json"}
try:
response = requests.post(GEMINI_URL, json=payload, headers=headers)
response.raise_for_status()
gemini_data = response.json()
self.log(f"Gemini API Response: {gemini_data}", level="INFO")
relevant_videos = self.filter_videos_based_on_ai(gemini_data, rows)
return {"videos": relevant_videos}, 200
except requests.exceptions.RequestException as e:
self.log(f"Error calling Gemini API: {e}", level="ERROR")
return {"error": "AI search request failed."}, 500
def filter_videos_based_on_ai(self, gemini_data, videos):
"""Filter videos based on AI response"""
if "candidates" not in gemini_data:
self.log("No candidates returned by Gemini AI.", level="WARNING")
return []
recommended_messages = gemini_data["candidates"][0]["content"]["parts"][0]["text"].split("\n")
cleaned_messages = [msg.strip().lstrip("0123456789.- ") for msg in recommended_messages]
self.log(f"Processed AI recommendations: {cleaned_messages}", level="INFO")
filtered_videos = [
"id": video[0],
"timestamp": video[1],
"video": video[2],
"ai_message": video[3]
for video in videos if any(msg.lower() in video[3].lower() for msg in cleaned_messages)
self.log(f"Filtered videos count: {len(filtered_videos)}", level="INFO")
return filtered_videos
NOTE: Save the python scripts in this folder on your HA instance: \your_IP\addon_configs\xxxxxx_appdaemon\apps
also add the scrips to your apps.yml file. See example below:
motion_snapshot_saver:
module: motion_snapshot_saver
class: SaveSnapshotAI
motion_video_saver:
module: motion_video_saver
class: SaveVideoAI
video_api:
module: video_api
class: VideoAPI
Step 5: Creating a Searchable Web UI β videos.html
I built a simple web interface to browse, filter, and search motion events.
Features:
Paginated Results (15 videos per page)
AI-powered Search
Filter by Date & Time
Note: Save the html in the www folder of Appdaemon and serve from there: http://homeassistant.local/5050/local/videos.html
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Motion Video Search (AI Powered)</title>
<style>
body {
font-family: Arial, sans-serif;
background-color: #121212;
color: #ffffff;
margin: 20px;
padding: 0;
text-align: center;
input, select {
padding: 10px;
margin: 5px;
font-size: 16px;
border: 1px solid #444;
border-radius: 5px;
background-color: #222;
color: #ffffff;
button {
padding: 10px 15px;
background-color: #007BFF;
color: white;
border: none;
border-radius: 5px;
cursor: pointer;
margin: 5px;
.grid {
display: flex;
flex-wrap: wrap;
justify-content: center;
gap: 10px;
.card {
border: 1px solid #333;
border-radius: 10px;
overflow: hidden;
width: 250px;
text-align: left;
background-color: #1e1e1e;
box-shadow: 2px 2px 10px rgba(255, 255, 255, 0.1);
cursor: pointer;
.card video {
width: 100%;
height: 150px;
object-fit: cover;
.card p {
padding: 10px;
font-size: 14px;
color: #bbb;
.fullscreen-container {
display: none;
position: fixed;
top: 0;
left: 0;
width: 100%;
height: 100%;
background: rgba(0, 0, 0, 0.9);
align-items: center;
flex-direction: column;
.fullscreen-container video {
max-width: 90%;
max-height: 80%;
border-radius: 5px;
.fullscreen-container p {
color: white;
margin-top: 10px;
font-size: 16px;
.close-btn {
position: absolute;
top: 20px;
right: 30px;
font-size: 30px;
color: white;
cursor: pointer;
.pagination {
margin: 20px;
</style>
</head>
<body>
<h1>Find Anything (AI Powered)</h1>
<input type="text" id="searchInput" placeholder="Enter a keyword or ask a question...">
<button onclick="performSearch()">Search</button>
<br><br>
<label for="dateFilter">Select Date:</label>
<input type="date" id="dateFilter">
<label for="startTime">Start Time:</label>
<input type="time" id="startTime">
<label for="endTime">End Time:</label>
<input type="time" id="endTime">
<button onclick="applyFilters()">Apply Filters</button>
<button onclick="clearFilters()">Clear Filters</button>
<div id="videoGrid" class="grid"></div>
<div class="pagination">
<button onclick="prevPage()" id="prevBtn" disabled>Previous</button>
<span id="pageInfo"></span>
<button onclick="nextPage()" id="nextBtn" disabled>Next</button>
</div>
<div id="fullscreenContainer" class="fullscreen-container" onclick="closeFullscreen()">
<span class="close-btn">×</span>
<video id="fullscreenVideo" controls></video>
<p id="fullscreenMessage"></p>
</div>
<script>
let videos = [];
let filteredVideos = [];
let currentPage = 1;
const itemsPerPage = 15;
const API_URL = "http://homeassistant.local:5050/api/appdaemon/videos";
const AI_SEARCH_URL = "http://homeassistant.local:5050/api/appdaemon/video_search";
async function fetchVideos() {
try {
const response = await fetch(API_URL);
if (!response.ok) {
throw new Error("Failed to fetch videos");
const data = await response.json();
if (!data.videos || !Array.isArray(data.videos)) {
console.error("Invalid API response format:", data);
alert("Error loading videos. Please check your API response.");
return;
videos = data.videos.sort((a, b) => new Date(b.timestamp) - new Date(a.timestamp));
filteredVideos = [...videos];
currentPage = 1;
displayVideos();
} catch (error) {
console.error("Error fetching videos:", error);
alert("Error loading videos. Please check your connection.");
function updatePagination() {
document.getElementById("pageInfo").textContent = `Page ${currentPage} of ${Math.ceil(filteredVideos.length / itemsPerPage) || 1}`;
document.getElementById("prevBtn").disabled = currentPage === 1;
document.getElementById("nextBtn").disabled = currentPage * itemsPerPage >= filteredVideos.length;
function nextPage() {
if (currentPage * itemsPerPage < filteredVideos.length) {
currentPage++;
displayVideos();
function prevPage() {
if (currentPage > 1) {
currentPage--;
displayVideos();
async function performSearch() {
const query = document.getElementById("searchInput").value.trim();
if (!query) {
currentPage = 1;
displayVideos();
return;
try {
const response = await fetch(AI_SEARCH_URL, {
method: "POST",
headers: { "Content-Type": "application/json" },
body: JSON.stringify({ query: query })
if (!response.ok) {
throw new Error("Failed to fetch AI search results");
console.warn("AI search response does not contain 'videos' array:", data);
alert("AI search did not return any videos.");
return;
filteredVideos = data.videos.sort((a, b) => new Date(b.timestamp) - new Date(a.timestamp));
currentPage = 1;
displayVideos();
} catch (error) {
console.error("Error performing AI search:", error);
alert("Error searching videos. Please check your connection.");
function applyFilters() {
const selectedDate = document.getElementById("dateFilter").value;
const startTime = document.getElementById("startTime").value;
const endTime = document.getElementById("endTime").value;
filteredVideos = videos.filter(video => {
const videoDate = new Date(video.timestamp);
const videoDateStr = videoDate.toISOString().split("T")[0];
if (selectedDate && videoDateStr !== selectedDate) {
return false;
if (startTime || endTime) {
const videoTime = videoDate.toTimeString().split(" ")[0].slice(0, 5);
if (startTime && videoTime < startTime) return false;
if (endTime && videoTime > endTime) return false;
return true;
currentPage = 1;
displayVideos();
function clearFilters() {
document.getElementById("dateFilter").value = "";
document.getElementById("startTime").value = "";
document.getElementById("endTime").value = "";
currentPage = 1;
displayVideos();
function displayVideos() {
const grid = document.getElementById("videoGrid");
grid.innerHTML = "";
const startIndex = (currentPage - 1) * itemsPerPage;
const endIndex = startIndex + itemsPerPage;
const paginatedVideos = filteredVideos.slice(startIndex, endIndex);
paginatedVideos.forEach(video => {
grid.innerHTML += `
<div class="card">
<video src="${video.video}" controls muted onclick="openFullscreen('${video.video}', '${video.ai_message}')"></video>
<p><strong>Timestamp:</strong> ${video.timestamp}</p>
<p><strong>AI Message:</strong> ${video.ai_message}</p>
</div>`;
updatePagination();
window.onload = fetchVideos;
</script>
</body>
</html>
Conclusion
This AI-powered motion search system has been a fun and rewarding project. Let me know if youβd like to build your own AI-powered motion search system!
