Building HA on Ubunu Linux
So I’m trying to get my environment all setup to be able to contribute to the project. I managed to get python 3.5 installed but when I try to run the “tox” command, I get this:
$ tox
ERROR: unknown environment ‘py35’
Any advice? Obviously I don’t know much about python or python dev. I did setup an environment using pyvenv-3.5 and then installed python3.5-gdbm, but I’m not sure what to do about this error for tox.
Thanks!
Nevermind, my bad. If I used pip to install tox, and it’s much better now.
Found the info here: https://github.com/balloob/home-assistant/blob/master/CONTRIBUTING.md
That’s what happens when you only get 30 minutes every 3 days to work on side projects. :wink:
