Anyone else getting these errors when using the built-in weather integration?
2020-06-18 09:09:08 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned 203
2020-06-18 09:09:08 ERROR (MainThread) [homeassistant.components.met.weather] Retrying in 19 minutes
On HA 0111.3
JensJ
(Jens Jacobsen)
2
Yes, same thing here:
2020-06-18 10:37:20 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned 203
2020-06-18 10:37:20 ERROR (MainThread) [homeassistant.components.met.weather] Retrying in 20 minutes
2020-06-18 10:37:20 ERROR (MainThread) [homeassistant.components.yr.sensor] Retrying in 18 minutes: https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/?lat=56.33017227938379&lon=10.04529118537903&msl=10 returned 203
Just saw that 0.111.4 is available and it came back after the update, have you tried that?
JensJ
(Jens Jacobsen)
4
Oh, update to 0.111.4 solved the problem. Thank you.
Moonbase59
(Matthias C. Hormann)
5
2020-06-19 01:49:41 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned 203
2020-06-19 01:49:41 ERROR (MainThread) [homeassistant.components.met.weather] Retrying in 17 minutes
on HA 0.105.1 (Hassbian)
EDIT: Also upgraded to 0.111.4 and works again.
