Button --> Cover Template --> Script doesn't work anymore - Update Issue?
Hi Community,
I have configured a cover template for opening my gate (shelly switch) which worked without any issues for a long time.
### - - - GATE - - - ###
    covers:
      gate:
        unique_id: aaa_bbb_ccc
        friendly_name: "Gate"
        value_template: "{{ states('binary_sensor.fritz_dect_1_alarm')|regex_replace('on','open')|regex_replace('off','closed') }}"
        open_cover:
          - service: script.gateopenclose
        close_cover:
        icon_template: >-
          {% if states('binary_sensor.fritz_dect_1_alarm') == "on" %}
            mdi:gate-open
          {% else %}
            mdi:gate
          {% endif %}
alias: GateOpenClose
sequence:
  - service: cover.open_cover
    data: {}
      entity_id: cover.shellyswitch25_10521cf977cc
  - service: automation.trigger
      skip_condition: true
      entity_id: automation.statusbar_gate_moving
mode: single
icon: mdi:gate-open
But since today I get the following error message in the Lovelace UI and it doesn’t work anymore,
Service script.gateopenclose called service cover.open_cover which was not found.
The log shows the following:
Logger: homeassistant.helpers.script.gate
Source: helpers/script.py:1805
First occurred: 18:26:52 (1 occurrences)
Last logged: 18:26:52
Gate: Error executing script. Service not found for call_service at pos 1: Service script.gateopenclose not found.
The only difference I can think of is a recent update of HA I did. My current version is:
Core
2024.2.3
Supervisor
2024.02.0
Operating System
11.5
Frontend
20240207.1
If I run the script manually, everything works fine.
For any support I would be very thankful. Thanks.
Problem solved. I renamed the script alias and was thinking that also renames the script itself…
