I have many sequences (flows?) to implement scene control on all my zwave switches & dimmers. Basically I have one events node listening to zwave_js_value_notification for any messages from X node_id.
This is where the issue lies… even though it doesn’t happen often, if I need to exclude and include or replace the device, the node_id changes.
Instead for listening for a node_id I would prefer to listen for the friendly_name or entity_id but I can’t figure out how. I looked at the information received by the events node but neither one is present, so I would need some way to look up the node_id I need to listen to by friendly_name or entity_id. Is this possible?
Edit: I am adding an example of what I am using:
[{"id":"8cf389e11fe0149e","type":"server-events","z":"d72cf2ab53741ef6","name":"zwave_js_value_notification","server":"6f1799ba.17e938","version":1,"event_type":"zwave_js_value_notification","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"},{"property":"event_type","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":160,"y":2580,"wires":[["6d00b1d68f853633"]]},{"id":"6d00b1d68f853633","type":"switch","z":"d72cf2ab53741ef6","name":"Living Room Light (169)","property":"payload.event.node_id","propertyType":"msg","rules":[{"t":"eq","v":"169","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":450,"y":2580,"wires":[["457ea124fbe778c5"]]},{"id":"457ea124fbe778c5","type":"switch","z":"d72cf2ab53741ef6","name":"Scene ID Btn","property":"payload.event.property_key_name","propertyType":"msg","rules":[{"t":"eq","v":"001","vt":"num"},{"t":"eq","v":"002","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":2580,"wires":[["c75b1c7cfcf1449a"],["c799344423c9bc3f"]],"outputLabels":["Scene 1","Scene 2"]},{"id":"c799344423c9bc3f","type":"switch","z":"d72cf2ab53741ef6","name":"Down","property":"payload.event.value_raw","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":850,"y":2640,"wires":[[],[],[],[],[]],"outputLabels":["1 Press","2 Press","3 Press","4 Press","5 Press"]},{"id":"c75b1c7cfcf1449a","type":"switch","z":"d72cf2ab53741ef6","name":"Up","property":"payload.event.value_raw","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":850,"y":2540,"wires":[[],[],[],[],[]],"outputLabels":["1 Press","2 Press","3 Press","4 Press","5 Press"]},{"id":"6f1799ba.17e938","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
