Hi all,
I am attempting to get Caddy working as a reverse proxy to connect to HA via domain internally with SSL.
I’ve got the following docker compose for Caddy:
services:
caddy:
image: caddy:latest
restart: unless-stopped
cap_add:
- NET_ADMIN
ports:
# - "192.168.100.2:80:80"
- "443:443"
- "443:443/udp"
volumes:
- ${DATA}/caddy/Caddyfile:/etc/caddy/Caddyfile
- ${DATA}/caddy/data:/data
- ${DATA}/caddy/config:/config
- ${DATA}/caddy/logs:/var/log/caddy
- /etc/ssl:/etc/caddy/certs
networks:
caddy_network:
ipv4_address: 172.100.0.10 # Assign a static IP within the subnet
networks:
caddy_network:
driver: bridge # This is the default, but explicitly stating it is good practice
ipam:
config:
- subnet: 172.100.0.0/24 # Define the subnet for your network
gateway: 172.100.0.1 # Optional: Define a gateway for the subnet
The following Caddyfile
# Global options
debug # For Caddy's internal process logs
log {
output file /var/log/caddy/caddy.log {
roll_size 10MB
roll_keep 5
roll_keep_for 720h # 30 days
level INFO # Or DEBUG for more verbose process logs
sarah.mycustomdomain.com {
tls /etc/caddy/certs/certs/*.mycustomdomain.com.fullchain.pem /etc/caddy/certs/keys/*.mycustomdomain.com.pem
reverse_proxy 192.168.100.2:8123
log {
output file /var/log/caddy/access.log {
roll_size 10MB
roll_keep 5
roll_keep_for 720h
format json # Recommended for structured access logs
# level INFO # Access logs are typically INFO level by default
However I do not seem to be getting anywhere.
Caddy is starting, doing a dns lookup I get the IP responding as 172.20.0.10 as per the dockerfile but nothing in the browser.
If I sh into Caddy, and do a curl I can confirm it can reach the HA container.
Yet there is nothing in the access log
Anyone any ideas how to get this working? Would really appreciate assistance in getting this going.
Thanks!
