Calculate power for a thermostat valve
I have radiators with thermostat valves which I want to use for an automation.
Each valve has an entity which gives me the current position in %
The idea: I would map a power to each radiator and calculate a current power.
template:
  - sensor:
     - name: "AZ HC power"
        unique_id: "az_hc_power"
        unit_of_measurement: "W"
        state: >
          {% set pers, power = states('sensor.az_thermostat_valve_state') | float, 2782 %}
          {% if pers == 'unknown' -%}
            0
          {%- else %}
            {{power*pers |round(0)}}
          {% endif %}
this works fine but the disadvantage is:
The max power is a value which is direct in the template (here the 2782W)
In the next step I would like to sum up the maximum power and the current power.
As the maximum power is here fix in the template I have no access to it.
How can I make the maximum power (here the 2782W) accessible ?
It would be great if I could add it as an attribute to the device but I have no idea how to do it.
Thank you
I am one step further (may be in the wrong direction :slightly_smiling_face:).
I found a possibility to add an attribute:
        attributes:
          radiatorpower: "2783"
        state: >
          {% set pers = states('sensor.az_thermostat_valve_state') | float %}
          {% set power = this.attributes.radiatorpower %}
            0
          {%- else %}
            {{ power }}
          {% endif %}
This leads to the expected output of “2783” for the state.
Problem 1: The expected type for the attribute is a string but I would like to use a float or integer
Problem 2: I can not use “power” or " this.attributes.radiatorpower" for a calculation.
If I use: {{ power | as float }}
I get the error:
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 423, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1950, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 4, in top-level template code
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1710, in forgiving_float_filter
    return float(value)
jinja2.exceptions.UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'radiatorpower'
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 540, in async_render_to_info
    render_info._result = self.async_render(variables, strict=strict, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 425, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'radiatorpower'
2023-01-20 18:31:30.182 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'radiatorpower'') while processing template 'Template("{% set pers = states('sensor.az_thermostat_valve_state') | float %} {% set power = this.attributes.radiatorpower %} {% if pers == 'unknown' -%}
  0
{%- else %}
  {{ power | float }}
{% endif %}")' for attribute '_attr_native_value' in entity 'sensor.az_hc_power'
