I’m trying to do a ROI calculation with a template sensor. But somehow I don’t get it working, and I expect it is something small…
{{((8000 / ((states.sensor.thuisbatterij_total | int) / (states.sensor.aantal_dagen_batterij_operationeel | int )) /365 | int )) }}
What I am trying to do:
Investment is 8000
sensor.thuisbatterij_total is the profit in total - current value approx 400
Sensor.aantal_dagen_batterij_operationeel is the number of days operational - current value 129
This deciding by 365 days a year
So I expect a result of 7. But it doesn’t give any result, nor a failure
What am I missing?
As Tom pointed out you aren’t using the correct method to get the state value.
Make sure you are using your parentheses correctly to get the right order of operations:
{{ ( 8000 / ( states('sensor.thuisbatterij_total') | int /
states('sensor.aantal_dagen_batterij_operationeel') | int ) ) / 365 }}
Or, you can use set statements to break it up:
{% set a = states('sensor.thuisbatterij_total') | int / states('sensor.aantal_dagen_batterij_operationeel') | int %}
{% set b = 8000 / a %}
{{ b / 365 }}
