I have created a new caldav calendar and managed to add it to home-assistant. Appointments of the calendar appear in the web gui of home-assistant.
From configuration.yaml:
calendar:
- platform: caldav
username: assistant
password: !secret caldav_password
url: https://XXXXXXX/caldav.php/assistant/calendar/
I had problems with the self signed certifcate of my server, but I disabled the check in the source currently.
I would like now to turn on a light if I there is a calendar appointment and I do not get the concept/syntax/naming scheme/pattern…
What I did:
I used the web gui editor and created this file:
# cat automations.yaml
- id: '1544375976196'
alias: New Automation
- entity_id: calendar.home_assistant_calendar
platform: state
condition:
- condition: state
state: 'on'
- alias: ''
data: {}
service: light.turn_on
Which does not work as far as I can see. My light is a tradfri and has the name light.sofa.
Obviously the action does not specify which light to turn on. Do I need to enter that as data?
How does the name of the calendar “calendar.home_assistant_calendar” in automations.yaml relate to the strings in configuration.yaml?
Is automation the way to follow for this? Or am I on the wrong track?
