Hi everyone,
I’m running into an issue with the calendar automation trigger in Home Assistant. My goal is to fire a reminder script a few hours before a calendar event that contains the word “trash.”
Here’s the automation I’m testing:
alias: Trigger Trash Reminder from Calendar
description: >
Starts the trash reminder script the evening before trash day.
- platform: calendar
entity_id: calendar.personal_calendar_time_flies
event: start
offset: "-06:00:00"
condition:
- condition: template
value_template: >
{{ 'trash' in state_attr('calendar.personal_calendar_time_flies', 'message') | lower }}
- service: script.trash_reminder_script
reminder_delay: "00:30:00"
Here is what I have tested so far:
- If I set the offset to 0, the automation fires off.
- If I set a negative offset (e.g. -06:00:00 or even -00:01:00), the automation never fires. Nothing shows up in the logs at the expected offset time.
- The calendar entity itself is updating correctly — I can see the event title and start_time in Developer Tools.
Is this a known issue with negative offsets on calendar triggers? Do I need to configure something differently to make the offset fire reliably? Or is there a workaround others are using to get reminders before an event?
