Hi all,
I have an automation with a local calendar event trigger and it gave me some odd results today that I’d like to understand. Probably best formatted as a few numbered questions:
A few minutes before the event was due to start I decided I didn’t want the automation to run this time, so I deleted the event but it fired anyway. Best guess is some sort of cache that hadn’t caught up to the calendar change?
With the automation running, it’s then designed to wait for the end of the event before doing some additional steps. With the event deleted I tried to terminate the automation by setting the attribute “current” to “0”. I thought that was the correct procedure, but it carried on running… Though now I type it out, I think there’s a service I was supposed to call after that, right?
Finally, at the end of the deleted event, the wait-for-trigger actually triggered and the automation finished. Is this the same reason it fired in the first place?
Oh and bonus question 4: Is there any condition I can use to double-check that a calendar event definitely exists before it runs an automation?
Double bonus question 5: If the automation is running and then the event is deleted, is that something that can be spotted in a wait-for-trigger?
Huge thanks for any assistance! And have a great day.
