Calendar: Search/replace in event title
Hi
I am using the AULA integration (Danish school information app) which adds calendars for each of my kids.
Their daily school schedule is created as a calendar sensor and I can display it in a card with:
type: calendar
initial_view: dayGridDay
entities:
  - calendar.skoleskema_name
This provides the following output:
What I would like to do is run a search and replace on the title so that “DAN” is replaced with “Dansk”.
I have tried with the following code but it does not work :sob:
type: calendar
entities:
eventTemplate: |
  {{ event.title
  | replace('m.samling', 'Morgen samling')
  | replace('DAN', 'Dansk')
  | replace('MAT', 'Matematik')
  | replace('BIB', 'Bibliotek')
  | replace('IDR', 'Idræt')
  | replace('ENG', 'Engelsk')  }}
Any pointers would be very welcome.
/Palle
The Calendar card simply displays the information from calendar.skoleskema_name.
The card’s options are explained in its documentation. There’s no setting or YAML option to rename a calendar event.
Because to eventTemplate is not a valid option.
aha, that explains alot :thinking:
Did you find a solution, i have same problem
I am looking to do the same thing here … Anything to report on that has worked?
Sorry for the late reply.
I did find a (nasty?) hack-a-round…
For the AULA integration, the information is stored in /config/skoleskema.json
The file is updated very often from the AULA integration (every minute’ish)
I run a rasberry Pi, so i wanted to minimize disk writes.
I installed spook (in HACS) and created 2 automation.
the first enables the AULA integration at 06:00.
The second disables the AULA integration at 06:15 AND executes a shell command.
(prepared in my config.yaml)
(reduced the shell command, because it’s REALLY big with three kids ;))
shell_command:
  skoleskema: |
    sed -i 's/\\"teacherInitials\\":\\"AJ\\"/\\"teacherInitials\\":\\"Anne Jensen\\"/g;
    s/\\"teacherInitials\\":\\"AJ\\"/\\"teacherInitials\\":\\"Arne J\\\\u00f8rgensen\\"/g;
    s/\\"title\\":\\"IDR\\"/\\"title\\":\\"Idr\\\\u00e6t\\"/g;
    s/\\"title\\":\\"MAT\\"/\\"title\\":\\"Matematik\\"/g;
    s/\\"title\\":\\"MUS\\"/\\"title\\":\\"Musik\\"/g;
    s/\\"title\\":\\"TYS\\"/\\"title\\":\\"Tysk\\"/g' /config/skoleskema.json
Also, æ, ø, å, Æ, Ø and Å should be replaced by… I looked it up in the original skoleskema.json file.
Hope this helps.
/Palle
