Calendar start/stop unable to determine
as a newbie to HA, I am trying to set a bool if I am in home office.
Having a calendar with whole day events, I try this (according to https://www.home-assistant.io/integrations/calendar/)
alias: OttoHO_Start
  - platform: calendar
    event: start
    entity_id: calendar.urlaube
    event: end
condition:
  - condition: template
    value_template: "{{ 'Otto HO' in trigger.calendar_event.summary }}"
  - if:
      - "{{ trigger.event == 'start' }}"
    then:
      - service: telegram_bot.send_message
          message: Otto HO Start
          entity_id: input_boolean.otto_ho
     else:
          message: Otto HO Ende
      - service: input_boolean.turn_off
mode: single
But when trying to save I get:
Message malformed: Unable to determine action
Anyone knows how to solve?
Best regards and thanks in advance,
Otto
you had a number of errors in syntax. i didn’t work on the logic, only the syntax.
are you using the automation ui builder to write your automation? it should have caught all of the errors you had…
i think it’s great that you’re grabbing code from the documentation (heck, you’re using the documentation… hurray!). once you grab the code and put it in the automation creator, then flip it to the ui editor and do your edits of the sample there as much as you can…
flip to yaml mode only when you must and when you want to see proper yaml generated to learn…
:point_down: :slight_smile:
Move else: to the left by one space.
FYI this is valid shorthand for template conditions.
No need for:
See: https://www.home-assistant.io/docs/scripts/conditions/#template-condition-shorthand-notation
well… shows my noobness :blush:
Thanks a lot! seems to work now!
I am still having problems with the gosh darn indentations of yaml…
If you use VSCode with the Home Assistant Helper extension it will alert you to indentation issues.
