Calendar Woes
I’ve got two calendar related issues. The first is that the states for my calendars aren’t accurately reflecting if I’m busy or not. Then, up until about an hour ago I was able to view my calendars in the Calendar section of HA. Now when I navigate to Calendar I receive the error “Error while loading page calendar.” I’ve Googled this error and searched this forum, but couldn’t find anything similar.
I’ve got 4 calendars total, 2 Google (1 work, 1 personal) and 2 Apple (1 personal, 1 shared with the wife). My Google work calendar seems to be reporting correctly throughout this entire experience while the others are not. I created test events on my 3 non-work calendars with varying degrees of success.
Testing and Troubleshooting:
1) Restarted HA several times
2) Created test events on each non-work calendar
3) These test events weren’t picked up until I rebooted HA again, but only my personal Google calendar and eventually my shared Apple calendar reflected that I was busy, my personal Apple calendar still shows I’m free.
4) Restarted HA a couple more times
5) No change and still can’t view the Calendar section, but once my personal Google calendar event was over the state reflected I was free with a state of “off” as it should.
6) I validated that my personal Apple calendar is still set to be publicly available.
7) Rebooted the HA VM
I am expecting that there’s a short period between creating an event and HA recognizing that an event has been created, seems to be a couple minutes in testing, so no complaints on this bit. But when 10-30 minutes have passed and my calendars still aren’t entirely accurate, that’s the part that makes me think they aren’t working correctly.
I’ve looked through all the settings, but don’t see any calendar specific options that may for instance let me restart the calendar portion of HA without having to reboot the entire server.
Any suggestions for getting visibility into my calendars again and having my calendars be reflected accurately?
Please post logs
Hello, sure, I can do that. Where would I retrieve these logs from? I checked Settings > System > Logs, but there wasn’t anything related to my calendar issues.
Are these caldev integration for the apple calendars? If yes, it updates every 15 minutes. So I’d expect updates every 15 minutes.
If the caldev integration is having issues, you’d see errors related to that. Those would be in your logs, where you specified. YOu can get more detail from those logs if you view the raw logs in the 3 dot menu.
I looked at using caldev initially, but ended up going with the Google Calendar integration as well as making my Apple Calendars publicly visible. The Apple Calendars I was able to add within the Calendar section of HA. I can’t see the page anymore, but I think there was a + or … that’d let you add calendars.
I know that at least the shared Apple calendar with my wife is registering in HA because when I look at the state it’ll show on/off fairly accurately, just not consistently.
After further testing, it looks like the Google calendars and the shared Apple calendar are syncing if I give them enough time to do so. My personal Apple calendar, not so much.
I can live with not being able to see my personal Apple calendar, I can just use my shared calendar or personal Google calendar instead, so no biggie. But to not be able to see the Calendar section in HA is a little frustrating. It’s pretty useful lol.
Any idea how I’d get logs for that?
Seems my issue has resolved itself. I’m not sure why, but I’ll take it! @petro thanks for your help!
I think the problem may have been due to your browser cache - When I get this error, I do a complete page reload (option-command-R in safari or Ctrl-F5 in Firefox.) and the issue disappears.
