I don’t find any media_player.speak_text
service in the dropdown list.
tts.google_say
It says:
Failed to call service tts/google_say. Service not found.
For clarity, I want to use this:
from a separate card, with a hard-coded text.
In configuration.yaml:
tts:
- platform: google_translate
In automation.yaml
service: tts.google_translate_say
entity_id: media_player.floor
message: 'May the Force be with you.'
But I don’t want to use Google Translate, I want to use my Google Home’s TTS.
Exactly, in the configuration.yaml enable tts.
And magic will happen
tts:
- platform: google_translate_say
Yep
But in mine I have
tts:
service_name: google_say
so tts.google_say is a valid service call on my system.
tts:
I want to use it in a card, not automation. So I tried adding this but if fails with:
Failed to call service tts/google_translate_say. extra keys not allowed @ data[‘data’]
It can’t find a google_translate_say
integration. Should I install it somehow?
I finally achieved it using:
entity: media_player.office_speaker
hold_action:
action: none
show_icon: true
show_name: true
tap_action:
action: call-service
service_data:
entity_id: media_player.office_speaker
message: My message
type: entity-button
Though by pure guess, as no example in that linked page doesn’t contain the data
key, so I think that it should be updated.
Thank you so much! I was looking for exactly the same solution. You’ve got me one step further.
Maybe you can help with my next step? I want to build a card where a text line can be typed, and TTS will send it to the speaker upon a press of a button.
I have this in my configuration.yaml;
input_text:
tts_syntesiser:
Then I have this card in Lovelace:
type: entities
entities:
- entity: input_text.tts_syntesiser
In another card (like yours), I want to say the text from the ‘input’:
entity: media_player.living_room_speaker
show_icon: true
show_name: true
tap_action:
service: tts.google_say
service_data:
entity_id: media_player.living_room_speaker
message:"{{ states('input_text.tts_syntesiser') }}"
type: entity-button
But of course - all it does is to read out the name of the enitity, and not its value (state).
I have checked the value (state) of this entity in the states tab, and it shows the correct string typed into the text box. So I guess my logic is right, but my syntax is wrong.
Can anyone help?
Remove the ’ ’
Nope - that doesn’t help. I still get this error message:
voluptuous.error. MultipleInvalid: extra keys not allowed @ data['data_template']
seems u using data: instead of message:
Thank you for your suggestion.
I did eventually solve the issue, but I forgot to post the result.So, here it is;
entities:
- entity: media_player.living_room_speaker
type: entities
The resulting card looks like this:
How did you get it to work?
I’ve a card in lovelace:
type: entities
entities:
- entity: media_player.googlehome8966
But I can’t fill in anything:
In my configuration.yaml:
input_text:
tts_syntesiser:
What I’m missing?
Thanks.
I’m not sure. This is my configuration.yaml
# Text to speech
tts:
#This is to synthesise TTS for the Google Home Mini
input_text:
tts_syntesiser:
Does this still work in 2021?
I can do TTS in Node red… (Service name default: tts.google_translate_say
But I can NOT get the card working?
Thanks for your help and time much appriciated
Yes, it works just fine. I never made any changes.
