Call-service API error (extra keys not allowed)
Hi all,
I have created a flow to turn off my Ecobee if any of my windows or doors (Ring contact sensors) are opened. I found an example flow online to grab the current state and store it before turning off the Ecobee. To test it I am changing the switch conditions (==offoff or !=offoff) to trigger output 1 or output 2 of the switch, so the debug output always shows ‘offoff’ (in real testing, it would show onon, offon, or onoff).
When I trigger output 2, which would simulate an open window or door (ignore the offoff as it would be onoff, offon, or onon), I get the expect behavior of an array created storing the config of the Ecobee when it is on (see flow1 pic).
When I trigger output 1, which would simulate restoring the Ecobee to its previous state once a window or door is closed, I get an API error. It says, msg:string(78) “Call-service API error. Error Message: extra keys not allowed @ data[‘state’]” (see flow2 pic).
Picture devstate shows the developer state of climate.thermostat in my HA.
I cannot figure out what the problem would be as the ‘set_temperature’ service debug output contains all the variables of the array that is stored.
Can anyone point out where my error is, please?
Thanks,
Rick
Here is the exported flow:
[{"id":"d880fc48.dd42e","type":"tab","label":"Ecobee Control","disabled":false,"info":""},{"id":"6eab2e2c.b9916","type":"join","z":"d880fc48.dd42e","name":"Windows&Doors state","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":320,"y":320,"wires":[["4984654d.b87a7c","fba8f7eb.5aba28"]]},{"id":"4984654d.b87a7c","type":"debug","z":"d880fc48.dd42e","name":"Message output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":180,"y":220,"wires":[]},{"id":"1ea5934b.07efad","type":"trigger-state","z":"d880fc48.dd42e","name":"Windows state","server":"f616e80b.293518","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"binary_sensor.windows","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on","propertyValue":"new_state.state"}],"outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":100,"y":300,"wires":[["6eab2e2c.b9916"],["6eab2e2c.b9916"]]},{"id":"f235ff40.56e94","type":"trigger-state","z":"d880fc48.dd42e","name":"Doors state","server":"f616e80b.293518","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"binary_sensor.doors","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on","propertyValue":"new_state.state"}],"outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":90,"y":360,"wires":[["6eab2e2c.b9916"],["6eab2e2c.b9916"]]},{"id":"f04a51b.91821b","type":"api-call-service","z":"d880fc48.dd42e","name":"Ecobee off","server":"f616e80b.293518","version":1,"debugenabled":false,"service_domain":"climate","service":"set_hvac_mode","entityId":"climate.thermostat","data":"{\"hvac_mode\":\"off\"}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":870,"y":480,"wires":[[]]},{"id":"fba8f7eb.5aba28","type":"switch","z":"d880fc48.dd42e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"offoff","vt":"str"},{"t":"neq","v":"offoff","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":550,"y":320,"wires":[["54b30a85.39a3d4","a5a0930.ed3ae7"],["66c60ddf.8a2ed4","d0818904.bf8628"]]},{"id":"54b30a85.39a3d4","type":"debug","z":"d880fc48.dd42e","name":"Switch restore output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":280,"wires":[]},{"id":"66c60ddf.8a2ed4","type":"ha-get-entities","z":"d880fc48.dd42e","server":"f616e80b.293518","name":"Get Climate","rules":[{"property":"entity_id","logic":"is","value":"climate.thermostat","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":110,"y":560,"wires":[["4aad1e24.6f117"]]},{"id":"4aad1e24.6f117","type":"function","z":"d880fc48.dd42e","name":"transform data","func":"const payloads = [];\nconst payload = {};\npayload.domain = 'climate';\npayload.service = `set_temperature`;\npayload.data = {\n    entity_id: msg.payload.entity_id,\n    state: msg.payload.state,\n    temperature: msg.payload.attributes.temperature,\n    target_temp_low: msg.payload.attributes.min_temp,\n    target_temp_high: msg.payload.attributes.max_temp\n};\n\n// create a blank message object with out new payload\nmsg = { payload: payload };\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":280,"y":560,"wires":[["e7da481b.6de7d8"]]},{"id":"f12c35ba.9d3488","type":"debug","z":"d880fc48.dd42e","name":"Climate state store","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":560,"wires":[]},{"id":"fe07c68b.0f5a08","type":"change","z":"d880fc48.dd42e","name":"","rules":[{"t":"set","p":"savedStates","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":560,"wires":[["f12c35ba.9d3488","f04a51b.91821b"]]},{"id":"a5a0930.ed3ae7","type":"change","z":"d880fc48.dd42e","name":"Get Saved States","rules":[{"t":"set","p":"payload","pt":"msg","to":"savedStates","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":120,"wires":[["6247c7cf.5cb858"]]},{"id":"8f420c5d.82373","type":"debug","z":"d880fc48.dd42e","name":"Climate state restored","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":860,"y":120,"wires":[]},{"id":"6247c7cf.5cb858","type":"split","z":"d880fc48.dd42e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":434,"y":120,"wires":[["719b7b39.cbf0e4","e66d815c.26bf4"]]},{"id":"719b7b39.cbf0e4","type":"api-call-service","z":"d880fc48.dd42e","name":"Ecobee Restored State","server":"f616e80b.293518","version":1,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":622,"y":120,"wires":[["8f420c5d.82373"]]},{"id":"e7da481b.6de7d8","type":"join","z":"d880fc48.dd42e","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"5","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":450,"y":560,"wires":[["fe07c68b.0f5a08"]]},{"id":"d0818904.bf8628","type":"debug","z":"d880fc48.dd42e","name":"Switch save output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":360,"wires":[]},{"id":"e66d815c.26bf4","type":"debug","z":"d880fc48.dd42e","name":"Split output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":620,"y":60,"wires":[]},{"id":"f616e80b.293518","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
It seems you need to remove the state from the message before you send it to the call service node.
I don’t understand. If I remove the state from the message, then how will it restore the state?
The error message says that state should not be called in the call service.
Are you talking about the extra keys not allowed @ data [“state”] message? Before I had the state in there, I had a similar error just trying to restore the attributes but I don’t remember what it said for sure.
Do I have to format this differently? I need the state to be restored more than anything else as that is what turns the Ecobee on and off.
I believe you are confusing the Ecobee state with the message data state.
Maybe I’m wrong… But the error message says to remove the state part of the message.
The ‘state’ part of the array holds the phrase ‘heat’ when it stores the prior thermostat data, which is the hvac mode the thermostat is in.
I don’t know what other state part of the message there could be. I don’t even know where to look on the net. Time for more Googling I suppose.
isn’t the Ecobee supposed to set that parameter itself?
I don’t know. I don’t have one but since it complains about you trying to set it, it seems that way.
I would try and add a function node with this code:
delete msg.payload.data.state;
return msg;
Well, I finally got it to work sort of. I took Hellis81’s advice and stopped trying to write the state parameter and figured out that I should read the state into the parameter “hvac_mode” instead of into a “state” variable.
Now the Ecobee settings are read into the array and written back out of the array without an error, but two other problems have cropped up.
The first is that the flow does not appear to be triggered when I open a window, only when I open one of the slider doors. I noticed that the debug output says “binary_sensors.doors” when it outputs one of the trigger states (“onoff”, “onon”, or “offon”). The trigger message is constructed from both the window and door sensors (hence the double wording) so I need to sort that out. I must not have the join command completely right yet. The flow does turn the Ecobee’s hvac_mode to “off” so that works at least.
Second, the Ecobee settings are output from the array now without an error, the temp setting looks to be applied, but the hvac mode does not get turned from “off” back to its previous state (currently “heat”).
Any one have any other insights, it would be appreciated.
