I’ve gone round the bend getting this automation to work, and it does now—but only when triggered manually.
I’m using the Camect integration through HACS, and I can see in the device the history of motion being noticed by HASS, but the following automation never triggers:
alias: Front Porch Camera Motion
description: prototype for all camera motion
triggers:
- type: motion
device_id: 267e7fc35eadc83d88626913b2161f1d
entity_id: 413296f02876d4de64d8e684e0f0eb67
domain: binary_sensor
trigger: device
conditions:
- condition: device
device_id: 249e41676a6817992966feb27e46d0d3
domain: device_tracker
entity_id: 0263339712c99b093a4e6c856e856ea0
type: is_home
enabled: false
actions:
- action: browser_mod.popup
metadata: {}
title: Front Porch Motion
dismissable: true
autoclose: false
content:
type: picture-entity
entity: camera.front_porch
timeout: 30000
target: null
device_id: d2ab9242428350849390ec3c451f9bc8
browser_id:
- d2ab9242428350849390ec3c451f9bc8
- 9d7b0adcea0bb0ebf56afeddfd76473f
mode: single
How can I troubleshoot this further? I’m very new to this.
How did you trigger it? By doing motion that changes the trigger to on? The change is when it triggers.
If it’s just on when you reload the new automation it won’t trigger.
Also if you do change the binary_sensor, the condition, whatever that is, needs to be true.
If the binary sensor changes to on (which you can check in the entity history), then it’ll trigger and create a trace which you can view. The action may be blocked by the condition, or the action itself might fail — the trace will tell you.
