Camera picture entity stream does not show current feed
I have a reolink camera as a picture entity within lovelace. When I first set up the camera, everything is working correctly. The picture shows a current still of the camera view, and then clicking the entity shows the preloaded stream. After a day or two, I notice that the video is no longer live. When I tap the entity to show the live view, it will show a time in the past, sometimes a view of nighttime when it is clearly mid day. It will play a few seconds of this previous time, then replay it constantly. I have checked the stream within VLC and it does play correctly there. A restart of Home Assistant usually fixes this, but I would like to figure out what is causing this and if there is a preventative measure from this happening again. Anyone have this issue?
