used to work just perfectly, both in States and Lovelace. After updating to either HA92.2 or the latest System 2.12 version. Must confess I hadn’t noticed timely to be certain, but since my Ha 84.3 system shows fine and uses System 2.12 also, it must be the Lovelace update?
The Lovelace camera won’t show up and only displays the Idle grayed screen. Tapping it doesn’t do anything either…
I know for a fact that the links and configs are correct, because my 84.3 system shows them as they should both in Lovelace and States, and the updated HA 92.2 system also shows the Bing map fine using States. Only Lovelace won’t get it back.
Has anything changed with the system config to need other settings?
thanks for having a look
thanks, I’ve commented these out now, but still no image is shown, while, even with the original posted config, the image shows perfectly in the other system and on States…
could the broken link icon be a pointer?
Ive checked the latest release changes but didn’t find a clue to this issue
also notice now that the camera_image isn’t necessary when the entity already is a camera, so taken that out too, as the incorrect tap-action…
no, this was an exact copy all way back to 84.3, or maybe even earlier.
Still, even with all the config errors, it shows no error in the log, and, does work just fine in the other system.
Moreover, even without all the errors simply using this now:
separate post with solution:
just had a (tiny) brainwave… tried a private window, without adblockers etc etc, et voila, the maps appeared immediately.
Disabling ABP on the HA instance allows to show all images. Could be something notable to others.
@tom_l thanks for your time and reflections on my config adjusted accordingly to be in specs. sorry. Though it still is remarkable the erroneous configs didn’t error out.
Ah sorry, what is ABP?
I just add HIK Cube camera to Lovelace, I check the link and image, but in Lovelace it show idle
Click on it and press play, always says “loading …” icon
- type: picture-entity
entity: camera.al_vento
camera_view: live
camera_image: camera.al_vento
