Hi everybody,
I run several cameras on raspberry pi
s via motion
. These cameras can be integrated in Home Assistant, however, it seems like the camera.snapshot
service is not available for those cameras. Or I just haven’t figured out how to…?
I thought of writing a bash or python script to run ffmpeg
in order to grab a still image from the camera feed, then save it somewhere that Home Assistant can access it (I generally use downloads/cameras
for those camera.snapshot
s that do work), and then grab the image and send it via Telegram
through Home Assistant, as I would any other snapshot.
However, this seems a bit overblown considering that all I want is to send a camera snapshot whenever the corresponding motion sensor is triggered.
Just to clarify, those camera
entities that have either still_image_url
or (I believe rtsp
in general), can successfully create snapshots, only the ones on raspberry pi running motion will not work.
Thank you for your ideas
