I was running hassos on raspberry pi3 and decided upgrade to more powerful device for streaming cameras and motion detection etc. Frigate got my attention and I pulled the trigger.
Now I am running hassos on HP Elitedesk i5. I did not want to get lost on Docker option due to lack of experience.
I have Hikvision DS-7116HGHI-K1 with 10 cameras.
I tried lots of different add ons and integrations to stream my surveillance cams and only ONVIF integration (kind of) worked. I cannot stream any camera but I have snapshots per 10 seconds on lovelace. If I click on any camera video never starts to play and closes after several tries.
I cannot stream videos from hikvision interface with local ip of DVR. I am able to playback only. But this is Safari and MacOS related issue I think. I can stream my cameras only from Hik-Connect app on iphone.
Mainstream and substream both changed to H264 from admin panel.
Frame rate 15. Onvif enabled.
I tried to use MotionEye, BlueIris, Generic cam, RTSPtoWebRTC but I am totally lost.
BlueIris asks server URL and tried every combination but still no luck.
MotionEye I tried to add every type of camera but failed again.
I have Wyze cam V2 and Anker Eufy 2K cam and I tried to add them to home assistant and I couldn’t add them too.
I don’t understand the logic and I am inexperienced in this area.
I need help from some experienced people.
Thank you
