Hello guys,
i’m having a little bit of a problem.
I recently bought some ESP32 Cams and they are pretty cool i have to say and i like them, tiny and cheap, although the video stream is enough for my projects
I tried different methods on the ESP32 Cam:
- Tasmota --> Cam Stream can not be importet in HA, motioneye or whatever
- the ESP32Cam Webserver from Arduino --> Quite good, but updating is a hell
- and ESPHome --> like it, also having many devices configured with ESPHome
Now my problem is, how can i get the stream of an ESP32Cam flashed with ESPHome to “another” place?
Found some hints with the Camery Proxy Stream and that was working a little bit, but only with the short access tokens, long access tokens didn’t work
Also found a maybe solution: the api_password function is deprecated, but on github there is a repository which brings this function back, but that’s not the “good” way.
Is there a solution for my problem?
I would like to integrate the stream of an ESP32Cam with ESPHome in Octoprint, because a little ESP cam fits better for my 3d printer setup than a big webcam and i only need it to look if my printer is not doing anything stupid, not for timelapse, so the camera quality would be good enough.
Hope someone has a solution for me (and maybe also others).
Cheers
