Have been getting the following error every once in a while but can’t seem to recreate it. It just seems to happen randomly.
2018-09-26 07:45:06.395444 WARNING AppDaemon: ------------------------------------------------------------
2018-09-26 07:45:06.398501 WARNING AppDaemon: Unexpected error in worker for App good_morning_routine:
2018-09-26 07:45:06.402396 WARNING AppDaemon: Worker Ags: {'name': 'good_morning_routine', 'id': UUID('870de344-2db7-4275-9aee-27f02f5a284c'), 'type': 'attr', 'function': <bound method GoodMorningRoutine.good_morning_routine_cb of <good_morning_routine.GoodMorningRoutine object at 0x744a5cb0>>, 'attribute': 'state', 'entity': 'input_boolean.good_morning', 'new_state': 'on', 'old_state': 'off', 'kwargs': {'new': 'on', 'handle': UUID('be9d0385-620c-407c-a94f-ebe8ee2b594d')}}
2018-09-26 07:45:06.405408 WARNING AppDaemon: ------------------------------------------------------------
2018-09-26 07:45:06.420711 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 171, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 56, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 849, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 314, in connect
conn = self._new_conn()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 180, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x725bde30>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='xxxxxx.duckdns.org', port=443): Max retries exceeded with url: /api/services/input_select/select_option (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x725bde30>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 590, in worker
self.sanitize_state_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/good_morning_routine.py", line 55, in good_morning_routine_cb
self.select_option('input_select.house_mode', 'Home')
File "/usr/lib/python3.6/site-packages/appdaemon/plugins/hass/hassapi.py", line 22, in func_wrapper
return func(*args, **kwargs)
File "/usr/lib/python3.6/site-packages/appdaemon/plugins/hass/hassapi.py", line 378, in select_option
self.call_service("input_select/select_option", **rargs)
File "/usr/lib/python3.6/site-packages/appdaemon/plugins/hass/hassapi.py", line 455, in call_service
apiurl, headers=headers, json=kwargs, verify=certpath
File "/usr/lib/python3.6/site-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 513, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='xxxxxx.duckdns.org', port=443): Max retries exceeded with url: /api/services/input_select/select_option (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x725bde30>: Failed to establish a new connection: [Errno -3] Try again',))
2018-09-26 07:45:06.436577 WARNING AppDaemon: ------------------------------------------------------------
Fatal read error on socket transport
protocol: <asyncio.sslproto.SSLProtocol object at 0x724e0c30>
transport: <_SelectorSocketTransport fd=16 read=polling write=<idle, bufsize=0>>
File "/usr/lib/python3.6/asyncio/selector_events.py", line 723, in _read_ready
data = self._sock.recv(self.max_size)
TimeoutError: [Errno 110] Operation timed out
