Can HA publish its commands/events to MQTT?
Is there a way to setup an MQTT for Home Assistant in a way, that it is publishing to the MQTT broker its commands and/or events?
Especially when a light was requested to turn on, I wish to have a message on MQTT that such a command was requested (i.e. a HA got the command to turn on the light, not that the light effectively has changed status).
Default MQTT integration does nothing more than sending a status of the HA instance to the queue.
I have used Node Red for somewhat similar tasks.
Get in event, send out MQTT message.
Thank you Tom! Exactly, what I was looking for.
It wasn’t that obvious when I was browsing the documentation.
Cheers,
Paul
