Does anyone know if this is possible now Google Assistant SDK is deprecated?
If so, how? I’m a newbie here so simpler guides are appreciated!
Hello Matt,
Believe it or not, but I at one time was sending the stop command to one of my Google speakers using TTS.
My daughter could not speak well enough to stop the speaker when it was alarming, so I gave her a button that said stop, and then she could stop the alarm from sounding…
There seems to be two HA-related things called Google Assistant SDK - an addon and core integration.
The deprecation notice in the addon was inserted a couple of months ago and refers to an upstream dependency becoming deprecated. That appears to have happened 6 years ago and was archived in 2023, so I’m confused.
However the core integration has no deprecation notice, so I assume it doesn’t have the same dependency and still works. I’ve had it installed for ages, but don’t actually use it.
