Can Hass compatible hardware press a elevator button?
HASS Hardware?
You can build anything you want to interface with any kind of switch/electrical interface. That has nothing to do with HASS though. You would just build it in a way that communicates over the network in some fashion
I hope this is a private elevator. Even so your insurance company are not going to like non standard modifications if they ever have cause to find out. Just something to keep in mind.
Yes on new install, retrofit… that’s unknown here. The yes comes from home elevator systems that can be controlled with call buttons and monitors made by Leviton. Retrofit, I’ve never seen any and as mentioned above, this area is highly regulated so be very careful in poking around in it.
Are you looking for something like this?
https://www.amazon.com/MicroBot-Push-2nd-Generation-Automation/dp/B071V7Y864
If you end up ordering it, it would be great to know if it can be integrated with HA - please keep us posted. Thanks!
did you end up getting the microbot? if so did you get it to work with HA?
