Can I automate wintermode?
Can I somehow enable or disable the wintermode by automation? I like to enable it when outside temp is 0 or below
If you provide some detail, we could provide a meaningful answer.
As your questions stands…
Probably.
I don’t know hoe the snow mode is implemented, but could not find an entity that represents the wintermode. Would be nice if an action comes available same as a switch, so I could automate it. for example something like:
action: homeassistant.turn_on
  entity_id: labs.wintermode
Likewise it would be possible to see if wintermode is on.
Then we can go loose: add rain mode with raindrops and party mode also!
Not currently. It’s still in preview, so there are still features and design revision to come, maybe…
Snowflakes? Done!
The rest: It is still in preview. You have to wait. Check the labs chatter.
