I have searched but I have not been able to find if this question has been asked.
I have a boatload of sensors and when I go into Developer Tools->States I have to continue to reload or click wait for all of the sensors to load. I am showing that I have 2,329 Entities.
When I finally get all of the sensors to load, I can then uncheck attributes and I can quickly go through all of the entities.
My ask is: Is there a way that I can default the attributes to be unchecked vs the default checked state?
Only Docker Container running on a Synology. I need access to the sensor to filter through the attributes. The Entities doesn’t give me the level of detail.
With a few sensors, I can see why the default is checked, but seems that unchecked is more logical.
As an example with my NCAAF CFP sensor, I have a python script that pulls the json data, but I refer back to the attributes when I am building a dashboard.
Is there any chance that I could do a feature request or could I build an automation that sets attributes to unchecked?
My experience is that the Attributes check box value is retained between sessions. I do also notice a little lag at time for the State tab. I’m certain the performance of your HA server will have an big impact on this but the performance of your front end device will likely come into play too.
Nick
