Can I change the conversation agent of my Voice Assist from within an automation?
I’d like to change the conversation agent in my voice assist from within an automation. Can this be done?
is ti for a dedicated device (e.g.: HA Voice PE) or globaly in HA ?
I was about to post this very same question! :slight_smile:
Specifically; if it’s possible to change the global ‘preferred’ assistant via automation?
I use a cloud based assistant & have an automation to detect if the property internet goes down, if internet is unavailable, I would like to use automation to change the preferred assistant to a local one that we also have running.
I’d like to be able to change the conversation agent of the default assistant so that I can switch between multiple LLMs programatically.
I have the same request, as I prefer to use a fast cloud open-source LLM such as Cerebras/llama-3.3-70b, but whan the internet goes down I tolerate the delay of using Ollama/Phi4 that runs on the same Proxmox/TrueNAS mini-pc together with the HAOS VM.
I like it insanely fast (Cerebras), but slow is better than none.
