I added the webostv component to control my LG tv. It works fine, but ever since adding it I keep getting this notification in home assistant. If I dismiss it, it will return next time I restart home assistant, if not before.
I don’t have any homekit-related hardware, and I just want to ignore it. Can I do that somehow?
If I press “configure” my tv shows a QR code and gives me some homekit related directions. I have no apple devices at all.
Thanks for your reply. No, I do not have discovery: in my configuration.yaml. It could be on by default somehow though, as new devices seem to be auto discovered. But isn’t this functionality that I want to keep? Is disabling it altogether the only solution?
If you complete the pairing process it should get rid of the notification without creating a new entity. See here for more info.
In short, Home Assistant can control HomeKit devices even if you don’t own Apple hardware. HomeKit displays currently aren’t supported, but Home Assistant will still discover them.
Thanks both, I will try removing default_config. I assume a ton of entities I have taken for granted will have to be set up again, but I agree it’s nice to have more control over what’s added to HA and not.
I will see if I can get through the pairing process.
