Can I have a sensor showing the state of a Global with a type: std::string?
Is it possible to show the state of a global if the type is a std::string ?
I have Globals similar to this…
globals:
  - id: global_example
    type: std::string
    restore_value: yes
Then some ‘automations’ which update the Global value (i hope!)?
    on_value:
      then:
       - globals.set:
           value: !lambda 'return id(global_example).state;'
What I’m struggling with now, is creating a sensor to display in the web server, what the Global value is.
Instead of a Global you could just use a text_sensor?
Oh, and Globals do not have a state property. It would just be id(global_example).
I’m trying to keep the values on reboot and the global ‘restore_value’ helps.
you are not clear if you want to set global or want to present it as sensor…
This for example updates template sensor to show global
id(mytemplatesensor).publish_state(id(myglobal));
Two ways to go around this:
You can either just copy the value of the text_sensor to the global in the on_value action of the text_sensor and then publish the value of the global to the text_sensor on_boot.
or if you just want to reflect the global in the text_sensor, create a lamba for the text_sensor that returns the global.
Sorry.
I’m using the Sim800l and would like to save the last message received as a global (as this can restore on reboot) and display that as a sensor (so i can visually see in the web interface.
You can use a template text sensor and have it returning the global in the lambda.
Thanks!
This did the trick…
    lambda: |-
      return {id(global_sms_sender)};
    update_interval: 60s
