Is there a way to declare variables in a script so that the fields show up in the visual editor? Say I’ve got a script that expects a variable called “message”. Can I expose that variable so that the visual builder knows that and gives me a prompt to enter the value for “message”?
That’s a simple example, but I’ve got a few scripts that accept multiple variables and I occasionally have to open the script to remember the names used for vars.
I tried adding a “variables:” key to the sequence, but that doesn’t appear to affect the visual builder.
When I look at my scripts in the developer tools > service calls screen, it does list the fields that I have defined.
fields:
light_target:
description: The light to target
example: light.livingroom_window
brightness_target:
description: The target brightness % to change to
example: 50%
But no they don’t show up in the visual script / automation editor.
Thanks. That’s helpful - I don’t see anything about fields in the script docs. I’ll start doing this in hopes that it’s something that the visual editor will someday support.
