Can I stop HA from dicovering my Google OnHub?
is there anyway I can stop my Google Wifi being discovered in HA as UPnP/IGD: OnHub? I have dismissed it a few times with almost each time thinking “hey didn’t I already do this” and now I have 5 OnHubs listed under UPnP
Thanks,
You can ignore it.
But it isn’t listed as a valid value
It must be discovered by some of those in the listing.
My suspect is the DLNA since that is the only generic.
But that does not either seem to be listed as ignore.
Perhaps you can change something in the routers?
What is the “issue” that it’s discovered? Is it the entities?
I know it’s silly but it was just the fact that is was always getting discovered on start up and I’m a little OCD so it was just hard to ignore the notification. I ended up just disabling uPnP in google WiFi, I only hope that it still let my chromecasts play (although the app says they need it to work)
EDIT: I doesn’t look like thats an option… I was hoping that since my chromecasts where already working it would be fine but I can no longer cast from PC but can still from phone
Try to close the browser on the computer and do it again.
We have that problem quite often, we just have to close everything, not just the tab.
hi, did you find a solution for this?
