Can I use Home Assistant OS as a regular Linux?
Hi
I’m wondering, is it possible to run on HA OS different applications for Linux?
If yes, what kind of Linux is it (which distro)?
No, see GitHub - home-assistant/operating-system: 🔰 Home Assistant Operating System
buildroot
But - you can use a “regular” Linux (Debian) to run HA Supervised on it.
As @m0wlheld says, it is not really a full Linux distribution so you can’t use it as such, but what you can do is install the portainer addon, and then run any docker container you want.
There’s a lot of docker containers out there for lots of purposes, so if it’s just a case of “I want to install X on my computer” you can probably do it by finding a docker container that runs X.
Ok, thanks guys!
