Can I use my phone as an NFC tag
Just hooked up an RC522 tag reader to an ESP, it reads tags ok, an gives a unique ID for each of the tags I have.
I really wanted to use my phone as a tag, but get a different Tag ID every time I present it to the reader, so a bit confused. My phone does have NFC.
Regards Dave
Hi there,
I have the same question. Is it possible, to use an Android phone as an NFC Tag? My idea is, to use the reader as a kind of lock. I simply like to use the phone, present it to the reader and the door should open…especially for the kids. They won’t forget the phone at home before leaving… :wink:
Thanks a lot, if anybody knows how to do that!
best,
charly
Can’t answer the original question, but for this use case I think doing the opposite makes the most sense (and is what I do for my exterior door and garage door). Just put an NFC tag by the door and tap it with your phone to lock/unlock/open/close it. Cheaper, more secure and easier.
Nice idea, have a few tags, some I cant seem to write to, get an error, but others I can.
Many thanks for the reply and easy solution
But then the telephone has to have HA installed ?.
Yeah, although that’s kind of the point (from a security standpoint). Only a HA user (for your instance) with the app installed can use the tags for anything.
I think the point is a lightweight solution that doesn’t require an app that people like kids will forget how to login.
@DaveTiff did you ever find a solution? I just order parts to make a reader, hoping there is a solution to this.
Hi Bob, no but you can use it the other way around, instead of using a Tag Reader. Put a tag on your wall and let you phone detect the tag.
I ended up building a fingerprint reader to unlock my door
