Hello. I am using the Duck DNS add-on on an Raspberry Pi running hass.io.
I wish to run Emby server on another computer on my home network and setup https connection for Emby on port 8920. Can I use the SSL certificate generated by hass.io? If so how should I go about doing it?
hi, those certs are regenerated slightly more often than every 3 months. You could just copy them from the /ssl directory on your HA instance to that Emby server. Try Configurator if you don’t want to use SSH.
